MICHV8 | -- 03-22-2016 @ 4:44 AM |
Will the 59AB fan location work in a stock 39 radiator configuration? If not, is it difficult to relocate the fan on the 59AB? Thanks to all...
42merc | -- 03-22-2016 @ 6:08 AM |
Short answer No. We need to know the body type your dealing with. If it is a '39 Deluxe, just change the the lower pulley to the '39 Deluxe pulley & use the corresponding fan. If it is a '39 standard or a truck, change the lower pulley to a single sheave & use the standards fan mount generator & fan. Truck would be the same except for the different hub length on the fan. This message was edited by 42merc on 3-22-16 @ 6:13 AM
MICHV8 | -- 03-22-2016 @ 2:47 PM |
42merc 39 convertible coupe...photo of engine (not mine yet) attached
42merc | -- 03-22-2016 @ 3:18 PM |
Yup, that's a 59A alright. I'll assume your convert is a Deluxe. Use a lower pulley from a '39 deluxe,or a '40 std or deluxe, or a '41 v8 engine. This pulley will have a single sheave and incorporate a hub to which the fan bolts to. You will also use the proper '39-'41 6 blade fan that bolts to this hub. On the 59A remove the 2 sheave pulley & install the '39-'40 or '41 pulley, then bolt on the new fan. Unbolt the fan from the 59A generator & throw under the work bench it's no longer needed.
MICHV8 | -- 03-22-2016 @ 4:51 PM |
42merc Thanks Chief!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9502 |
