MICHV8 | -- 03-21-2016 @ 9:19 AM |
Any gothas with using a 1946 59 AB engine with a 39 trans? Thanks!
TomO | -- 03-21-2016 @ 2:05 PM |
It should work fine. I hope that you blocked the fingers on the pressure plate to remove tension as you tightened the pressure plate to the flywheel. Tom
MICHV8 | -- 03-21-2016 @ 5:56 PM |
Thanks Tom. I just wondered because I think that 46 used a 10 clutch plate and thought there might be something different with the pressure plate application to a 39 trans. Sounds good, though....
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9500 |
