1935ford | -- 03-19-2016 @ 12:06 PM |
Am installing a late '36 engine with domed pistons and 68-0649B/50B heads (7.5 to 1 c.r.) in my '35. Could someone please advise the correct distributor? Thanks in advance! Roger J.
ken ct. | -- 03-19-2016 @ 1:50 PM |
The flat top coil is correctfor a late 36. I just happened to have one fully rebuilt with coil if interested PM or cell 1-203-260-5945. All usa parts used in it. ken ct.
TomO | -- 03-20-2016 @ 8:21 AM |
You could also use the 35 coil and distributor. Tom
drkbp | -- 03-21-2016 @ 5:12 AM |
The three hole biscuit coil and distributor is the '35 "look". The flat top two screw coil and distributor will work on the '35 engine but it "looks" '36. I have one that I keep as a spare for my '35 Cabriolet. Conversation starter when you raise your hood. Ken in Texas
ken ct. | -- 03-21-2016 @ 5:34 AM |
I also have a correct 35 dist w/correct 35 domed coil if that's what you are wanting,both are complete rebuilds w/ all caps and gaskets. ken ct same contact as above.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9494 |
