Bongo | -- 03-02-2016 @ 7:20 AM |
Can I use a 8 volt battery in my 1939 ford with a 1946 ford engine, 6 volt alternator and starter with out damaging anything?
ken ct. | -- 03-02-2016 @ 7:22 AM |
Forget the 8V. ken ct.
len47merc | -- 03-02-2016 @ 7:28 AM |
Bongo - why do you want to use an 8V battery? Help us understand what is driving your thinking this may be necessary. Steve
TomO | -- 03-02-2016 @ 7:55 AM |
To answer your question, It depends on what condition is making you want to use an 8 volt battery. High resistance connections can start a fire, so it is better to fix the problem, rather than add a band-aid to circumvent the symptoms. I do not recommend using an 8 volt battery. It is better to fix the electrical problems and use a 6 volt battery. Tom
cliftford | -- 03-02-2016 @ 8:21 AM |
Speaking form experience, I totally agree.
trjford8 | -- 03-02-2016 @ 8:39 AM |
Whatever problem you are having an 8 volt battery is not the answer.Let us know the problem or symptoms and we can help solve them and you can continue to use the 6 volt battery.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9449 |
