dggohl | -- 02-22-2016 @ 12:54 PM |
I'm planning on putting a 53 Mercury flathead into my 52 Ford Mainline. Are there any major concerns about the swap? Waterpumps? Drive shaft? Crank diameter?
cliftford | -- 02-22-2016 @ 1:12 PM |
Many years ago I replaced a 6cyl in a 53 ford with a 53 merc engine. As I recall, I used the merc bell housing, flywheel and clutch and it bolted right in.
TomO | -- 02-22-2016 @ 4:54 PM |
The v-8 blocks are identical. Ford used different water pumps, bell housing and intake manifold. Tom
dggohl | -- 02-23-2016 @ 8:00 AM |
If i have the complete Merc motor, it should just drop in from what i understand? Except the water pumps? Thanks.
cliftford | -- 02-23-2016 @ 9:30 AM |
yes,and I'm not sure you will have to change water pumps. I'm thinking that the merc pumps will bolt to the ford mounts, but check it out. I don't trust my memory any more.
TomO | -- 02-24-2016 @ 7:03 AM |
If the Merc has the 52-53 water pumps, you should not need to change them. I would change the intake to use the less troublesome Ford carburetor. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9410 |
