fenbach | -- 02-21-2016 @ 11:29 AM |
anyone have any experience with 6 volt LED headlight bulbs? and recommend any. I have original reflectors and halogen reflectors that use H4 base bulbs. for that matter, has anyone been able to use bob drake's 6 volt halogens without melting the wires? they draw 10 amps. apiece.
34billct | -- 02-22-2016 @ 8:29 PM |
Yes I tried the kit with reflector and ballast and was disappointed. Adjust low beam and high beam is up in the trees. Adjust high beam and low is on the ground in front of the car, I sent them back. The best I have found so far is NOS 1188 lamps 50/32 cp
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9403 |
