rdofloor | -- 12-26-2015 @ 9:51 AM |
does any one know where I can find a intake manifold for a 36. I have been fighting a oil leak out the rear main and tried every thing. As last resort I decided to pull the engine and I found a hole in the manifold on the bottom, it is made out of alum. Roger Oliver 515-231-2500
trjford8 | -- 12-26-2015 @ 10:46 AM |
Roger, post an ad in the wanted section of this site and also on Fordbarn;www.fordbarn.com
pinnsky | -- 12-26-2015 @ 11:51 AM |
I found an excellent used one on eBay earlier this year.
ken ct. | -- 12-26-2015 @ 3:41 PM |
There are many holes in the bottom of the intake , what does that have to do with a leak at the rear seal ???????? Ive had a 36 for 25 yrs and know it pretty well. ??? ken ct.
rdofloor | -- 12-27-2015 @ 11:44 AM |
I have enclosed a couple of pictures
ford38v8 | -- 12-27-2015 @ 1:04 PM |
Roger, that's an exhaust burnout from the heat riser. Good manifolds are not scarce, post in the classified section as advised. Alan
40 Coupe | -- 12-28-2015 @ 4:03 AM |
I can not determine from the photo the exact location of the hole but if the exhaust gases are entering the engine valley it could cause pressure build up in the block leading to oil leakage from the rear main. The cars used an aluminum manifold and the commercials may have a cast iron intake manifold if yours is aluminum consider having the hole welded since it is on the valley side of the intake. Cast iron can also be welded. The 36 intake is unique to 36 see the restoration book.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9251 |
