engine | -- 12-04-2015 @ 10:05 AM |
I need to know how to remove the 2 pins and spring in the shift lever to replace the grommet. I have tried to push both pins in at the same time as well as pushing the pins on through the grommet. Thanks
40 Coupe | -- 12-04-2015 @ 10:26 AM |
Both pins in at the same time, then pull the lever out. They can stick in position.
engine | -- 12-04-2015 @ 10:35 AM |
Thanks, will get some help to do so.
40 Coupe | -- 12-05-2015 @ 4:33 AM |
the person who pulls should not pull too hard or the spring and two end pins can go flying.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9185 |
