rogbell | -- 11-18-2015 @ 11:19 AM |
I'm almost finished wiring under the dash of my '36 except for one last item. Not sure which terminal on the ignition switch is for the battery? Using the normal left/right designation for all parts, which is it, the left or right? The switch is not marked to indicate. Thanks.
Don Rogers | -- 11-18-2015 @ 1:34 PM |
It doesn't make any difference. The switch terminals are isolated from ground.
rogbell | -- 11-18-2015 @ 2:55 PM |
Don, thanks again.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9157 |
