jal9846 | -- 11-10-2015 @ 10:10 AM |
I am looking for a paint formula for the 1935 Color called "Light Gun Metal". I have some old PPG Ditzler codes, but the PPG systems cannot cross reference those codes to any grey color. If someone has a formula for this color, can you please post or share where I can find. Thank You. Justin
Whifty | -- 11-10-2015 @ 9:38 PM |
http://paintref.com/cgi-bin/colorcodedisplay.cgi?color=Light%20Gun%20Metal%20Gray&tditzler=IM1525,IM280&rows=50
TomO | -- 11-11-2015 @ 8:06 AM |
Go to http://www.autocolorlibrary.com/ TCP Global can mix your color from the code. Tom
jal9846 | -- 11-11-2015 @ 11:15 AM |
Guys, thanks for the help. I found the codes previously on that paint reference website...but in working through 3 very reputable paint supply shops now none of those codes show up anywhere in the PPG or Dupont systems. One of them only shows up in PPG as a diamond metallic white. So I am not sure where those codes came from....or have since been superseded, etc. I really hate to spend $80 on a quart of paint from TPC as a spray out test....but maybe I will have to. I was hoping someone might have a car that is that color...and have an actual formula they would share.
TomO | -- 11-12-2015 @ 7:04 AM |
You can go to one of the paint shops and look through their color books to find a color close to the color that you want. Then have them modify the formula to give you the exact shade. There have been a large number of changes in the automotive paint supply industry in the past few years and many paint formulas cannot be made any more. I ran into that with my 53 Lincoln when I tried to buy some touch up paint. Tom
Whifty | -- 11-12-2015 @ 7:10 PM |
I recently had the same problem. The paint store couldn't find the formula so my painter called PPG and they cross referenced it to the new formula. Perfect match. (800) 647-6050
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9136 |
