isetta08 | -- 10-29-2015 @ 9:36 AM |
I am working on a 1937 V860 with the welded alloy sides on the block. The alloy is not magnetic so I assumed aluminum. Marty Willim said the sides are stainless. My question is should this block be hot tanked? I have heard stories of leakers. Will the hot tank open the old welds?
37 Coupe | -- 10-31-2015 @ 7:35 AM |
I don't think hot tanking is going to make it any better.The "tin" sides are stainless and Ford quickly went away from it as my May 1937 60 hp was a solid cast iron block. Personally I would not invest to much money into a rebuild on this block. I had two cast iron ones and both were bought by frustrated owners of the tin side ones that were leaking,one when into a motorcycle however.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9106 |
