John Lubinski | -- 10-25-2015 @ 3:30 PM |
In need of a maintenance manual showing how to attach convertible top any clues out there?John Lubinski
Drbrown | -- 10-25-2015 @ 9:50 PM |
The only thing I've seen in the commonly available Ford Service manual is a diagram of the hydraulic system.
cliftford | -- 10-26-2015 @ 6:25 AM |
If you are talking about the canvass top and pads, I suggest that you have it done professionally, unless you have some expertise in this area. Otherwise,it is not an easy job. I speak from experience.
pauls39coupe | -- 10-26-2015 @ 8:05 AM |
John , Try Stew's Auto Trim in Eaton Rapids (517)663-3990 They do good work and are reasonably priced. Paul
John Lubinski | -- 10-26-2015 @ 1:57 PM |
What I need is the measurement of the bow (rear) to the floor.
John Lubinski | -- 10-26-2015 @ 2:00 PM |
Paul,we have a guy here in bliss field to do the job,but am having problems lining them up .
flathead48 | -- 11-01-2015 @ 6:57 AM |
John, to get the proper height of rear bow, find the center of bow and car body. Measure over 17.5 inches from center on both sides and the proper height at these too points should be 18-5/16 from bottom of bow to top of tack strip. Hope this helps.
joe b | -- 11-03-2015 @ 7:42 AM |
John, I was looking at ads in a car magazine I get. There is a company called Hydro-E-Lectric 800-343-4261 hydroe.com They may be able to help. Just a shot.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9100 |
