camsaure | -- 10-24-2015 @ 9:00 PM |
Can anyone copy and post or send me copies of the needed pages on the calibration of the Ford Heyer test set?
40 Coupe | -- 10-25-2015 @ 4:44 AM |
Maybe...what do you need? What model test set?
camsaure | -- 10-25-2015 @ 2:21 PM |
Thanks for the reply. It is model number H-2, serial 6260. I am told that there are instructions somewhere on calibration of this set, apparently they are not in Ford service bulletins.
40 Coupe | -- 10-27-2015 @ 4:55 AM |
Is this the "Diagnosis Test Set" or the "Distributor Stroboscope" Check my PM and send me an email.
juergen | -- 10-27-2015 @ 10:59 AM |
The 37-41 Service Bulletins book has an extensive compilation on the Heyer Test Set instructions starting with a reprint of the 34 Bulletin on this subject and also covering the later stroboscope option. As I remember correctly, they covered all the material found in the instruction booklet given to Ford mechanics which came with the set I used to have.
40 Coupe | -- 10-29-2015 @ 4:09 AM |
Ford started with the Heyer test about 34-5 and used the model H-1. Some have a distributor stroboscope some do not as it was an option. Heyer came out with several other test sets prior to the war. None of these are the model H-2,I find no information regarding the H-2 pre war. Post war Heyer made the test set larger and divided test between two sets The "Diagnosis Test Set" the other "Distributor Stroboscope" I do not have model numbers for these two test sets. You may want to look at Ford Service Bulletins under "Equipment" E-100TAC or E-100TS for information prior to the war. Lots of technical information. There is some Heyer technical information for the post war units.
Don Rogers | -- 10-29-2015 @ 4:57 AM |
The August 1935 Ford Service Bulletin (Vol 16 No. 7) has an entire section devoted to Service Instructions for the Heyer Test set. (pg 302 thru 316) This message was edited by Don Rogers on 10-29-15 @ 4:58 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9097 |
