harvsfl | -- 10-10-2015 @ 7:41 AM |
Is Corn Head grease good to use on wheel bearings. Can't find the fiber based grease used ears ago.
TomO | -- 10-10-2015 @ 10:26 AM |
Use Sta-lube SL-3131 available at NAPA. Tom
Old Henry | -- 10-10-2015 @ 3:29 PM |
Cornhead grease is way too thin for weight bearing bearings. It is for gear and gear bearing lubrication. I use Mobil 1 synthetic grease. It is for extreme pressure which bearings are.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9066 |
