silverchief | -- 10-09-2015 @ 2:54 PM |
Trying to attach original resister pic.
40cpe | -- 10-09-2015 @ 4:50 PM |
You should open your original post and click on the "reply" box in the upper right corner to post more information on the same subject. It keeps all the information in one "thread". Sorry, I can't help with information on your resistor.
Old Henry | -- 10-09-2015 @ 10:29 PM |
As trjford8 said in your other post, the part on the left of both of your pictures is the resistor and is the same in both pictures.
silverchief | -- 10-10-2015 @ 1:34 PM |
I know the location and the function of the resister on the unit. My question is - does the unit pictured hanging under the dash ready for installation - perform the same function as the original unit - or is it something entirely different? If it performs the same function, is the difference in design simply an improvement over my original unit? Thanks for your input.
juergen | -- 10-10-2015 @ 1:57 PM |
It looks to be the same. In your first picture one lead is the power lead and feeds two circuit breakers with the output leads being separate. in your second (this) picture, trying to see through the cover it looks like the center lead feeds both circuit breakers and the other two leads are the outputs.
silverchief | -- 10-11-2015 @ 5:28 PM |
Thanks for the input. Because the new unit has no metal cage, and appears different in design, I was not sure it served the same purpose and was OK to install.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9064 |
