Grant | -- 10-09-2015 @ 5:14 AM |
What would the correct valve spring be for a 1936 LB engine? Is there a difference between a '36 LB valve spring and the earlier '36 version? What about 1937? Would a '37 valve spring be the same diameter and length and tensile strength?
TomO | -- 10-09-2015 @ 6:44 AM |
The correct spring is P/N 40-6513-B. The replacement is P/N 78-6513. The replacement springs fit 32-48 engines. Tom
Grant | -- 10-09-2015 @ 7:50 AM |
Thanks, Tom. I would have thought that the part number might have been 68-6513 for a '36. Does the 78 prefix mean that FoMoCo came out with a new-and-improved valve spring for the 1937 models?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9060 |
