46fordnut | -- 10-06-2015 @ 2:45 PM |
lost low beam headlights both . only have high beams bad dash switch or floor switch . thank you in advance valve covers can't leak if they don't exist .
kubes40 | -- 10-06-2015 @ 2:58 PM |
I just went through this three days ago. Turned out in my case to be the head lamp switch. It can be the dimmer as well.
46fordnut | -- 10-06-2015 @ 3:01 PM |
ok ill try and post what my findings are thank you valve covers can't leak if they don't exist .
40cpe | -- 10-06-2015 @ 5:01 PM |
If you have a floor dimmer switch the light switch feeds power to the dimmer. power comes out of the dimmer either to the low or high beams. I can't see the headlight switch being bad if it is feeding power to the dimmer switch. Or both headlight bulbs are bad on the dim side.
46fordnut | -- 10-06-2015 @ 10:20 PM |
no low beams at all only high beams work at this point. i thinking if power goes to high beams most likely a bad floor switch. valve covers can't leak if they don't exist .
TomO | -- 10-08-2015 @ 6:29 AM |
Don't forget that both low beams could have been burned out. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9052 |
