snotdoc | -- 10-06-2015 @ 3:36 AM |
I would like to add swan neck, hinge mounted side mirrors to my 1935 coupe. Unable to remove either upper hinge pin thus far despite lots of penetrating oil and banging away. Advice appreciated!
ford38v8 | -- 10-06-2015 @ 9:15 AM |
The pin is knurled near the head. I had to drill the head to relieve the knurled 1/2". The swan neck mirror is not correct for your pickup. Go for the straight neck version. Alan
fenbach | -- 10-08-2015 @ 8:53 AM |
i'd go with a hinge pine removal tool https://www.bobdrake.com/FordItem.aspx?Item=TL-100 as I recall, I had to use a small 1/4 drive socket as a sleeve to keep the push pin lined up with the hinge pin.
transbytip | -- 10-08-2015 @ 7:19 PM |
I have a very good air chizel that will move them out might give it a try cover paint with heavy tape wherew are you located?Cliff. with reguards Cliff. Tipton
snotdoc | -- 10-09-2015 @ 7:09 PM |
Thanks for the recommendations, gentlemen! Cliff, I am located in West Michigan. A friend here does have an air chisel that I might try. Terry
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9049 |
