whitfield | -- 10-04-2015 @ 7:55 PM |
Hello - I am fixing the steering column and column shift mechanisms on my 1940 Ford Coupe. I damaged the clip that secures the shift mechanism and the shift fulcrum pin to the top of the column. I can't seem to find a replacement clip. Any ideas where I could find a replacement or a suitable alternative part? Pic is attached. Thanks Eric
alanwoodieman | -- 10-04-2015 @ 8:43 PM |
I lost one of mine and used a brake clip for a replacement. the clip that secures the parking brake lever to the pin on the rear brake shoe. easy to find at any auto parts store
whitfield | -- 10-07-2015 @ 12:06 AM |
Alan - I really appreciate the tip on this. I was hoping there was an easy work around. Thank you very much. Eric
40 Coupe | -- 10-07-2015 @ 4:06 AM |
The clip does not appear to be unusable just get it flat. I have never seen any new clips for sale, either find a good used or remake one from a washer. The groove in the clip is supposed to be slightly V shaped.
whitfield | -- 10-17-2015 @ 8:35 PM |
40 Coupe - sounds good. Should be easy enough to flatten the one I have. Thank you.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9046 |
