MOXIE | -- 03-08-2010 @ 9:40 AM |
Can a optima 6 volt battery be charged.
TomO | -- 03-08-2010 @ 10:33 AM |
Yes, but use a slow charger, no more than 6 amps Tom
4dFordSC | -- 03-08-2010 @ 2:26 PM |
Yes, as long as your card is not over its limit.:)
BrianCT | -- 03-08-2010 @ 4:55 PM |
The Optima site says 10 amps maximum.
ford38v8 | -- 03-08-2010 @ 7:28 PM |
I think it also depends on where you are... Most dealers Stateside don't accept American Express
v8teditor | -- 03-09-2010 @ 5:24 PM |
This may or may not be helpful. At one time Walmart had a 6/12V battery maintainer for less than $20 that worked just fine on the Optima battery. A maintainer is NOT a trickle charger. It charges the battery only when needed and you leave it on the battery all the time when the vehicle is not being used. Unfortunately I can't remember the item # for the charger. I've got one in the garage somewhere and if I can find it, I'll post the number here. I had this info in the V-8 TIMES with the part # a few years back but can't remember when.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=904 |
