Willyb | -- 09-29-2015 @ 7:05 PM |
I have both rear regulators for my 36 tudor but I'am not sure how to identify left from right. I am looking for information on window angle and the sequence for sliding the two pins in the slides on the bottom of the window channel
Robert/Texas | -- 09-30-2015 @ 4:35 AM |
I don't know how much this would help you but it sure helped me with my '37 fordor front driver's side window. https://www.youtube.com/watch?v=gdcN-ypFNBc This message was edited by Robert/Texas on 9-30-15 @ 4:37 AM
Don Rogers | -- 09-30-2015 @ 4:56 AM |
Willy, Here is a picture of a right hand rear quarter window regulator. This should help you identify which is which. Don
Willyb | -- 10-02-2015 @ 9:58 AM |
Thanks for the info. I have identified right from left and I watched that video several times. My 36 has a different track and regulator. There is a small screw inside the front track near the inside end it stops the spring pin from moving any farther in that direction. I wonder if that screw is suppose to be removed so that the spring pin can enter the track from the center rather than te end
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9034 |
