flathead48 | -- 09-26-2015 @ 4:29 AM |
When Fomoco put tube shocks on late 47 and 48 autos, where did they mount the bottom of the front shock? Thanks
TomO | -- 09-26-2015 @ 7:07 AM |
I believe that the lower shock mount was on the axle. Tom
trjford8 | -- 09-26-2015 @ 8:53 AM |
You should find a hole in the axle about midway between the kingpin and the wishbone. The mounting bolt runs through the shock and then through the axle.
flathead48 | -- 09-26-2015 @ 9:04 AM |
Thanks guys for the info, Regards, Arick
shogun1940 | -- 09-28-2015 @ 7:09 PM |
when i did mine i had to take the wishbone axle and spring to a machine shop with a bridgeport to drill the hole.
flathead48 | -- 09-30-2015 @ 3:58 AM |
Thanks shogun 1940,
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9015 |
