Superdave | -- 09-25-2015 @ 4:33 AM |
Anyone have the wire breakout for the Mallory distributor on 39? There are three wires going to the coil from the distributor, but I have no idea where they go. This car has been modified to 12 volts neg. gnd.
4dFordSC | -- 09-25-2015 @ 7:52 AM |
Have you checked with Bubba? http://www.lindertech.com/bhrs/
Superdave | -- 09-25-2015 @ 1:57 PM |
Sent them an email.. Thanks. I gave up trying to make heads or tails of the Mallory site.
Whifty | -- 09-25-2015 @ 2:21 PM |
RED WIRE: Connect to the positive side of coil (+). GREEN WIRE: Connect to the negative side of coil (-). BROWN WIRE: Connect to engine ground. http://static.summitracing.com/global/images/instructions/MAA-unilitedistributorwiringdiagramtestproced.pdf This message was edited by Whifty on 9-25-15 @ 2:27 PM
Superdave | -- 09-26-2015 @ 6:06 AM |
Thank you. I guess what threw me off was the illustrations didn't look anything like the distributor on the car. but I see the same principal applies to all of them.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=9011 |
