fordv8j | -- 09-02-2015 @ 6:54 AM |
WHILE AT MOTORFEST 6, WE WERE AT THE FOUNDATION MUSEUM TRIED TO START THE 38 COUPE,JUST CLICKED,CHECKED BATTERY TERMINALS THEY WERE OK,THOUGHT THE NEW OPTIMA BATTERY WAS DEAD IT WASNT..CECIL POLAN SAID THE STARTER WAS STUCK..TRIED ROCKING THE CAR IN HIGH AND REVERSE..DIDNT WORK..FINALLY JACKED IT UP LOOSENED THE STARTER KNOCKED IT LOOSE FROM ITS MOUNT,TIGHTENED BACK..STARTED..1ST TIME IN 50 YEARS..JUST WANT TO 'THANK' ALL WHO CAME TO MY RESCUE....THANKS
TomO | -- 09-02-2015 @ 7:08 AM |
That is a very pretty 38 coupe. I enjoyed seeing it run down the road. The 39 and up engines had a bracket that attached to the starter bolt and the oil pan to eliminate the problem. If you have the 21 stud engine, you may be able to fabricate a bracket. The Ford P/N is 51A-11140. Tom
fordv8j | -- 09-02-2015 @ 8:54 AM |
MY 38 HAS THAT BRACKET
joe b | -- 09-02-2015 @ 1:47 PM |
DON'T FEEL LIKE THE LONE RANGER. MY STARTER IN MY '41 STUCK ALSO. WAS UNABLE TO GET THE STARTER OUT SO IT BECAME A FLATHEAD ON A FLAT BED. BACK HOME MUCH PRYING AND PROFANITY AND I GOT IT OUT. TOOK IT TO A STARTER SHOP AND THEY FOUND NOTHING WRONG. IT HAD A NEW FLY WHEEL AND STARTER BRACKET. OH WELL (:
Old Henry | -- 09-02-2015 @ 3:04 PM |
Lower case font is easier to read rather than ALL CAPS.
joe b | -- 09-02-2015 @ 5:49 PM |
SORRY HENRY I'LL be more careful in the future.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8928 |
