flatheadfan | -- 08-27-2015 @ 8:39 AM |
First, I know the '35 and '36 have different wheel bolt patterns but does the carrier itself have the same bolt pattern where it bolts on to the car? Thanks Tom
trjford8 | -- 08-27-2015 @ 5:06 PM |
To my knowledge yes, they have the same pattern.
flatheadfan | -- 08-27-2015 @ 5:29 PM |
Thanks Trjford8. I am considering changing the wheels on my '36 from a wide five to the smaller bolt pattern. In order to retain a deck mounted carrier I would need a '35 carrier on my '36. It sounds like it will be a bolt on item. And yes, I am aware that there are different carriers for the different bodies. Thanks again. Tom
trjford8 | -- 08-28-2015 @ 12:47 PM |
Tom, just for info there is a 3'6 fordor in my area with the 35 wire wheels on it and on the spare. This car is what tells me the '35 tire carrier will fit a 36.
wmsteed | -- 09-01-2015 @ 8:37 AM |
When I put hydraulic brakes on my '36 coupe in '52 I used '41 brakes/drums and wheels. I changed the spare tire mount to a '35 mount which bolted onto the stock '36 mounting without alteration. Years later when I switched back to wide five wheels on '39 drums I put a '36 spare tire mount back on to the car. The only difference between the '35-36 mount is the '35 mount is solid steel, where-as the '36 is stamped steel. I still have the '35 spare tire mount hanging on the wall in my garage. Bill 36 5 win delx cpe
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8908 |
