Gene N. | -- 03-03-2010 @ 5:16 PM |
Bracket 014-2467 m Master cyl -1051 G size 1 1/16 Clutch Pedal 01A 7520-AZ Brake Pedal 01A-2455 Are these from 1939/1940 ford car, if not what are they from Thank you in advance Gene
40guy | -- 03-03-2010 @ 6:48 PM |
I can tell you for sure the brake and clutch pedals are 1940. 01A is a 1940 prefix. I'm sure someone else will weigh in on the other two components.
37RAGTOPMAN | -- 03-04-2010 @ 4:41 AM |
looks like 1940 to me,I know these will not fit 1939 if that is what you wanted to do, 1939 is a one year only, I know because I converted a 1937 platform pickup to hydraulics my 3 cents worth 37RAGTOPMAN
jerry.grayson | -- 03-04-2010 @ 2:00 PM |
The number 014-2467 is not a good part number. The number for a 1940 car is 01A-2473. This is a bracket and shaft assembly. The number is most likely a casting number and not a part number. The pedal number, 01A-7520 is for a 1940. All the parts you have are most likely 1940. The part number for a 1939 bracket is 91A-2467. Casting numbers found sometimes on a part are not necessarily the part number, sometimes it is. 1939 and 1940 pedal assemblies are completly different.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=885 |
