khaysb | -- 08-12-2015 @ 8:30 AM |
I have a rebuilt split core" radiator in my 1940 convertible club coupe and want to know if I can pressurize the system with a 4 lb radiator cap without harming the cooling system. I have new Bob Drake water pumps and 170 degree thermostats. My intent is to further insulate myself from overheating situations by increasing the boiling point. Is a 4 lb cap safe for my car?
joe b | -- 08-12-2015 @ 10:12 AM |
I have a 1941 with a split radiator. I have been running a 4 lb. cap for 10 years with no problem. I have 160 degree thermostats and no overheating.
TomO | -- 08-13-2015 @ 7:51 AM |
The 40 radiator has the overflow coming out of the top of the tank and the cap is below it on the slanted portion of the top tank. A pressure cap will not provide pressure unless the overflow is modified or you use a pressure relief valve like the one from Skip Haney in the over flow. I have been using the pressure relief valve and a 4 lb pressure cap for about 15 years now and it has worked fine for me. I installed the pressure relief valve at the bottom of the overflow tube using flexible fuel line. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8848 |
