carcrazy | -- 08-07-2015 @ 8:08 AM |
How do you remove the knob from the headlight switch of a 1953 Ford?
ken ct. | -- 08-07-2015 @ 9:47 AM |
I don't think the knob comes off the shaft. Theres I think a spring loaded button on top of the switch under the dash that is pressed down and pull on the knob and shaft and both come out together. If I remember right?? ken ct.
carcrazy | -- 08-07-2015 @ 7:52 PM |
Thank you Ken. You were right, I located the push button on top of the switch, pushed it, and pulled the knob and stem out with no problem.
ken ct. | -- 08-07-2015 @ 9:32 PM |
Boy that tested my long term memory,55 Chebbys were the same way,lucky shot. lol Glad I helped. ken ct.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8834 |
