John Lubinski | -- 08-06-2015 @ 11:23 AM |
I have a 48 Ford pickup I need to know how to replace the generator with an alternative 6Vpos ground .I see them in different books but they show them for v 8s.I have a flat six(226)'Can this be done? I don't drive the truck much cause the battery will not stay fully charged and sometimes won't start thanks John Lubinski
cliftford | -- 08-06-2015 @ 9:27 PM |
First, is your generator charging? Is your battery in good condition? Are all the cable connections and ground straps [body to engine] clean and tight and in good condition? If the gen is charging and you have these other problems, switching to an alternator won't help.
TomO | -- 08-07-2015 @ 6:25 AM |
John, Clifford has it right, an alternator will not solve problems with a poorly maintained electrical system and may make things worse. Have you had a load test done on your battery to determine if it is still in good condition? If not, that is the place to start. Here is a link to an vendor that claims to have an alternator for your truck. http://www.qualitypowerauto.com/category_149/Alternators-for-Generator-Conversion.htm Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8831 |
