MICHV8 | -- 08-05-2015 @ 8:50 AM |
I’ve attached a couple photos of the glove box and dash frame and wondering if I am missing a piece? The car was apart when I bought it. Thanks for your help!
MICHV8 | -- 08-05-2015 @ 8:51 AM |
second
juergen | -- 08-05-2015 @ 11:06 AM |
Can't really tell from your second picture. There should be a tab with a hole on either side of the bottom dash reinforce piece spaced to match your glove box door hinge. See photos below This message was edited by juergen on 8-5-15 @ 11:09 AM
juergen | -- 08-05-2015 @ 11:07 AM |
And here is the other side.
MICHV8 | -- 08-06-2015 @ 8:27 AM |
Jerry Yes, the tabs are there and I see how it works. Thanks
MICHV8 | -- 08-07-2015 @ 6:56 AM |
Still piecing this together. When installed, the door has quite a bit of side to side freeplay (1/8 or so)...should I try to bend the tabs or install a filler on the spring wire?
40 Coupe | -- 08-07-2015 @ 8:56 AM |
try to figure out if one or both of either the door hinge or the dash brackets are slightly bent and correct. 1/8" is too much movement, but the door should move freely without binding. about 1/32" free play This message was edited by 40 Coupe on 8-7-15 @ 8:59 AM
MICHV8 | -- 08-08-2015 @ 7:03 AM |
will do...what does the spring loaded button latch to? Is there a clip on the actual glove box? Right now the door simply hangs open... Thanks for your help.
40 Coupe | -- 08-09-2015 @ 4:07 AM |
The spring loaded ball on the door latches the door closed to a metal clip mounted to the top of the glove box (comes in a kit including the rubber bumper for the door). There is also a reinforcement metal plate that should come with the new hard board glove box it mounts above and outside the glove box.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8824 |
