rdove | -- 07-18-2015 @ 4:48 PM |
Does anybody out there have a picture of 1948 H-series 6-cylinder accelerator linkage in a 2 door sedan? I need a picture of the linkage at the intake manifold. Thanks in advance.
ken ct. | -- 07-18-2015 @ 10:26 PM |
They used a rod type as did the V8's but don't know if its the same length. The "H" engine used a cable type arrangement to the choke only. ken ct.I have 6 cyl rebuilt carbs and parts thereof if you need any. ken ct
rdove | -- 07-19-2015 @ 5:53 AM |
I need the arms that are attached to the intake manifold if you have them. I think they are held in place by a cotter pin.
ken ct. | -- 07-19-2015 @ 10:53 AM |
Do you have a Green Bible pg. 426 shows parts do you mean # iga-9584 or #iga- 9518. These I have though they are not attached to the manifold ,their part of the carb. Ken ct. call 1-203-260-5945 cell.
rdove | -- 07-19-2015 @ 11:52 AM |
The closest picture I can find in the Green Bible is on page 399. It shows a G-series 6 cyl. linkage. Part # 9724. The parts I need are not attached to the carb. I've attached a picture. The linkage I need are toward to bottom left of the picture. This message was edited by rdove on 7-19-15 @ 11:53 AM
ken ct. | -- 07-19-2015 @ 1:01 PM |
Oh I see,that is usually called a bell-crank,that I NO got. Sorry, no idea where to get one. Try Bob Selzam 1-732-928-9421 M,T,T,F. Closed Wed. 10 am to 4 pm.
cliftford | -- 07-20-2015 @ 8:26 AM |
I just might have this part. I have an old 6cyl engine in my boneyard that looks a lot like this. It came out of a 46 model. let me know. Gene
rdove | -- 07-20-2015 @ 11:05 AM |
Thanks, I'll try him.
rdove | -- 07-20-2015 @ 11:10 AM |
Gene, According to the Green Bible, they were the same from 41-48 on all 6 cylinders. If the one you have is in good shape, I would be interested. The one I have is slightly bent. Randy
cliftford | -- 07-20-2015 @ 12:25 PM |
Hi Randy, the one I have is also slightly bent and has some surface rust, but it could be staightened and used. let me know if you are interested. You can call me at 509-670-0408. Gene.
rdove | -- 07-20-2015 @ 6:59 PM |
Thanks Gene,but it sounds about like the one I have. If I can't find one in better shape I will get back in touch with you.
ken ct. | -- 07-20-2015 @ 10:05 PM |
Why not try and straighten out the one you have. Heat a vice and a small ball peen hammer works wonders for them. Ive fixed many V8 ones using this method. ken ct.
rdove | -- 07-21-2015 @ 1:28 PM |
Thanks Ken, I will probably have to give that a try.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8756 |
