vacaville john | -- 07-11-2015 @ 1:43 PM |
need to how much you can drill heads to make them easy to remove from the studs or is this a thing to do.
ford38v8 | -- 07-11-2015 @ 2:30 PM |
Never a good idea, for two reasons: One, the gasket area is very limited, and you don't want to reduce it further. Two, the stud/head relationship is often your last chance of preventing coolant escape. Best just to use anti-seize on the exposed studs before installation of the heads. Don't forget sealant on the studs that protrude into the water jacket. Alan
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8730 |
