Chris in MA | -- 06-26-2015 @ 4:54 AM |
Hi, Does anyone who has installed seatbelts in their 38-40 Tudor have photos to share of the location of the anchor bolts for the front belts. Looking for pics of both the inside and under the car. I'm using Julianos belts and anchors. Much appreciated, Chris It worked before I fixed it...
trjford8 | -- 06-27-2015 @ 7:21 AM |
I don't have photos, but I anchor the inside half of the belt next to the center tunnel. Measure from that point about 15" and then place the outside belt. Belts go through the floor pan and not the frame. Make sure your anchor bolt kit has the large washers that go on the bottom of the floor pan. I usually put the seat in my normal seating position. I then mount the belts as close as practical to the back of the seat bottom.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8670 |
