TNation | -- 06-24-2015 @ 7:01 PM |
Any info will be appreciated. In particular, I need a source for the bale which holds the light switch in place. Also need to know which pitman arm would work best. I'm sure I will have more questions. Thanks. Terry N
MGG | -- 06-24-2015 @ 7:51 PM |
Bob Drake as the bail it is their part no. B-3647-A
TNation | -- 06-25-2015 @ 2:57 PM |
Thanks, MGG.
JM | -- 06-25-2015 @ 3:42 PM |
You would use a stock '37-'39 bail and its mounting hardware. I would suggest using your stock '36 pitman arm. This is what we did when installing a '37-'39 steering box in a '36 Phaeton. John
TNation | -- 06-27-2015 @ 7:24 AM |
Thanks, John.
flatheadfan | -- 07-02-2015 @ 5:41 PM |
TNation- Check your "inbox." Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8660 |
