ronnyflyboy | -- 06-18-2015 @ 7:28 AM |
I tried to clean the gas gauge on my 34 ford. I cleaned the glass tube well but I cant blow through the gas gauge. I want to pour MEK in. Can anyone help. Ron
kubes40 | -- 06-18-2015 @ 8:23 AM |
Mine was clogged as yours apparently is. I tried the soaking method to no avail. I ended up using carburetor cleaner and a very tiny wire as a "snake" to go through the tube. Took a lot of patience. Only a very small amount of wire "travel" at a time. It worked well, but again, be patient.
woodiewagon46 | -- 06-18-2015 @ 9:03 AM |
McMaster-Carr sells miniature non scratch wire brushes from .014 and greater that are 3" long. Perhaps that would work. I use them on carb ports and jets.
ronnyflyboy | -- 06-19-2015 @ 7:10 AM |
Thank you guys for the help, I used the wire and the brake fluid and it worked perfect !! Thank Ron
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8641 |
