37 Coupe | -- 02-27-2010 @ 3:44 PM |
Since I usually only drive in the spring through summer wondering if 140 wt.is absolutely necessary for rear axle. I have been running the 90wt in transmission all year long but have usually kept the 140 in rear,seems sometimes it is slow to shift on a cool day until it goes down the road a ways. Also since I have about equal amounts of 140 and 90 could I just use half of each? Wouldn't that be about like multiviscosity? Stuff I have is GL4 Stay-Lube says safe for brass stuff on label.
Stroker | -- 02-27-2010 @ 4:05 PM |
I never ran anything but 90 wt. in the Columbia. I lived in So-Cal. and our operating temps were from 26 deg. to 100 deg. I think 140 is a bit thick for summer ops.
4dFordSC | -- 02-27-2010 @ 6:38 PM |
I use SAE 80w-90 GL-5 in my Columbia, with operating temperatures ranging from 25-100+ here in SC.
47dlx | -- 02-28-2010 @ 7:01 AM |
37 coupe i recommend you use a multi viscosity oil 85-140 i do not recommend trying to mix two different viscosities! columbia guy
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=863 |
