40topless | -- 06-06-2015 @ 9:38 PM |
Do graphite head gaskets need to be retorqued
40 Coupe | -- 06-07-2015 @ 4:14 AM |
All the head gaskets need to be re-torqued after installation. It is not the fault of the gasket but the steel engine studs do stretch slightly especially with heat. So re-torque (cold) after the first full heat up and then again after about 100 Miles.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8594 |
