custom | -- 02-25-2010 @ 12:14 PM |
I need to hook-up wires at the gas tank
40guy | -- 02-25-2010 @ 1:39 PM |
O.k.
ole_Bill | -- 02-25-2010 @ 3:41 PM |
When you finish, let us know how it worked out.
flathead4rd | -- 02-25-2010 @ 4:50 PM |
There is only one wire at the gas tank and it hooks up to the sending unit.
custom | -- 02-25-2010 @ 5:28 PM |
Thanks for the reply!! The tank has been repaired and has a good coat of black finish which I thought would interfear with the ground factor. If so should a seperate ground wire to the body be used???
ford38v8 | -- 02-25-2010 @ 6:40 PM |
Yes. Anytime there is a possibility of a poor ground, run another to a known ground. This advice especially include headlights. Alan
trjford8 | -- 02-28-2010 @ 7:21 PM |
Run an extra ground wire from one of the sending unit screws to the frame. Make sure it is contacting clean metal.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=858 |
