1937sedandelivery | -- 05-31-2015 @ 8:55 AM |
Hello, Not sure what the correct name is, but the part that I have a question about is the front overhead panel to which the visors mount. Question: is this panel unique to 1937? or is there one from another year that I can use in order to keep my sedan delivery stock? Thanks, Gregg
TomO | -- 06-01-2015 @ 7:34 AM |
Your question is very hard to answer, unless someone has restored the 37 Panel Delivery. The trim colors and patterns were changed between years and that gave the part a new part number, so the Body Parts Catalog may not work. I would check with the V-8 Club's 37 Adviser to see if he can give you some guidance. Tom
1937sedandelivery | -- 06-01-2015 @ 7:46 AM |
Thanks Tom, will do.
37 Coupe | -- 06-01-2015 @ 2:40 PM |
I have a 1937 Ford Body Parts list book,Form 7572 printed in June 1938. I think the part you are referring to is called the windshield header panel and I can tell you that my book list the same number for closed cars and the sedan delivery. It is 78-701418,I think that is what they are referring to in the book. It should not be tough to find if you are missing this panel I see them on Ebay from time to time. I cannot seem to find my 1938-1939 Ford body parts book to see if this same panel stayed with the #78 prefix,meaning it would be the same 1937 through 1938 and mayby 1939,assuming a panel was still used with top mounted wipers these years.
1937sedandelivery | -- 06-02-2015 @ 7:24 AM |
Great, that makes total sense to me. I will keep an eye out for a coupe one.
cpipp01@aol.com | -- 06-02-2015 @ 12:37 PM |
Hi I have attached a photo showing the 37 Ford windshield header panel part number 78 701418 it is a one year only part, I have also included in the same photo the windshield header panel wiper motor covers for a 37 Ford panel, pickup or truck I do not know the part number. The covers are also a one year only part, I hope this helps.
1937sedandelivery | -- 06-03-2015 @ 8:43 AM |
this totally helps, thank you very much. I haven't seen those wiper motor covers before. Gregg
37V8 | -- 06-04-2015 @ 4:35 AM |
I would suggest that you call Roy Nacewicz for an answer. He has restored a '37 sedan delivery (and a '32 sedan delivery). http://www.fordscript.com Our hours of operation are: Mon - Thursday 9:00 AM - 11:00 PM Eastern Time Fri - Sat - Sun 9:00 AM - 5:00 PM Eastern Time Phone: 734-654-9450 Fax: 734-654-9530
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8567 |
