V8JR | -- 05-30-2015 @ 6:15 PM |
What is the proper method to set the idle adjustment screws on a Stromberg 97 Carb. Does scr*w*ng them in lean out or richen the idle mixture? Thanks - Jimbo
ken ct. | -- 05-30-2015 @ 9:31 PM |
automobile carbs are in for leaner and out for richer , you are controlling the gas flow.!!! motor cycles are opposite as you are controlling air supply. 1 turn out is just about on the money slight tweeking might be necessary 1/8 to 1/4 turn may be necessary either way to get smoothest running. ken ct.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8566 |
