tphiel | -- 05-25-2015 @ 11:00 AM |
when setting steel studs in aluminum, do you use locktite , stake em'.or what? I'm setting studs in an aluminum intake manifold. And would like to clear this up. regards….tp
shogun1940 | -- 05-25-2015 @ 4:03 PM |
i would use locktite and stake them. stainless i hope.. you can still get disimilar metal corrosion .
ken ct. | -- 05-25-2015 @ 9:40 PM |
Ford never locktited or staked them why now. I would coat threads with never-seize.Ive never seen any back out before , OMO If you double nut them when going in or out they can be removed if wanted. ken ct.
kubes40 | -- 05-26-2015 @ 9:26 AM |
Wow! For once I actually agree with advice given by KenCT. There is NO reason you need to stake studs in to an intake manifold. None at all.
tphiel | -- 05-26-2015 @ 11:44 AM |
Thanks for the input. regards …tp
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8553 |
