jones36_deluxe | -- 05-18-2015 @ 10:40 AM |
looking to find out if the 36 flat head would have had C-4 spark plugs in it (22mm plugs) instead of the 18mm Champion #7's, 21 bolt manifold and no markings that i can see This message was edited by jones36_deluxe on 5-19-15 @ 9:10 AM
ken ct. | -- 05-18-2015 @ 1:56 PM |
All 34-36 maybe later had 18 MM plugs. I use Champion # D-21 in mine . ken ct.
40 Coupe | -- 05-19-2015 @ 3:44 AM |
Champion 7 three piece with brass top without the name "FORD" these are 18mm. The C-4 is for the 4-Cyl of 33-34.
jones36_deluxe | -- 05-19-2015 @ 9:06 AM |
I thought that the 18mm plug was correct. but they are too small for the plug hole on the head on my flathead My dad bought the coupe in '55 and it has been in the carport and garage since '59 he doesn't recall ever changing the heads, just had water pump issues. (we are 3rd owners of this car) the spark plug holes measured with my calipers are around 20mm and appear to be fine thread. Im not sure why these heads have large plug holes, have more heads at dads in NC, but don't want to swap if these were original Appreciate the help This message was edited by jones36_deluxe on 5-20-15 @ 8:16 AM
40 Coupe | -- 05-20-2015 @ 4:25 AM |
Are the "heads" you have, on the car, made of aluminum or cast iron? Are there any identifying marks, like a part number? Is there a Ford script on the heads? Can you post a photo of the head installed on the engine? When we think of a "manifold" usually the intake or exhaust comes to mind. Did the car have C-4 plugs installed?
jones36_deluxe | -- 05-20-2015 @ 8:09 AM |
It looks like they are 32 cast iron heads on it 2 1/2" recess around plug hole we have aluminum heads @ my dads and some more cast heads small number and symbol on lower left This message was edited by jones36_deluxe on 5-20-15 @ 8:12 AM
jones36_deluxe | -- 05-20-2015 @ 8:11 AM |
plug hole
drkbp | -- 05-20-2015 @ 10:19 AM |
Jones, The engine you show appears to be a later block than 1936. I could be mistaken but it looks like there are block off plates on it. That would probably make it a 1937 21-stud block. If that is the case, the heads are not original to that block anyway. If you can get plugs that fit, I would just put them in and enjoy the car if the engine runs well. Ken in Texas
jones36_deluxe | -- 05-20-2015 @ 11:03 AM |
thanks for the feedback. just starting rebuild on the v8 that was the motor that was in it when dad got it in '55 long way to go to get her on the road Kevin This message was edited by jones36_deluxe on 5-20-15 @ 11:04 AM
jones36_deluxe | -- 05-20-2015 @ 11:14 AM |
here are some marks on the back of the block thats a 18 at the bottom This message was edited by jones36_deluxe on 5-20-15 @ 11:21 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8533 |
