my50ford | -- 05-15-2015 @ 12:42 PM |
I have a new aluminum radiator for my 50 ford. the radiator is rated 16 _ 18 PSI. Should I use a 16 lb cap or the 7 lb cap that the 50 ford calls for?
ford38v8 | -- 05-15-2015 @ 5:23 PM |
I would say go for it but for your original heater core. You don't need that much pressure anyway. Alan
flathead4rd | -- 05-16-2015 @ 7:04 AM |
I would stay with the 7 lb cap or less. Your water pumps might start leaking at anything higher.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8525 |
