fordnuttoo | -- 05-09-2015 @ 3:20 PM |
Is there a newer pinion yoke that uses u-bolts to connect the u-joint instead of the flange type, that will fit the '52 rear end?
trjford8 | -- 05-10-2015 @ 8:32 AM |
contact; www.currieenterprises.com. These guys have been doing rear end work for a long time and will probably have the answer.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8504 |
