flatfoot | -- 05-08-2015 @ 8:34 PM |
Thanks to all the tire replacement suggestions. I put some new Firestones on without even a wheel balance and the shimmy is gone. Car is handling well. Thanks to all; you are all very helpful. Dale
TomO | -- 05-09-2015 @ 7:03 AM |
Dale, I am glad that your shimmy is gone. It is better to add your solution or more comments about a problem to your original post. That way someone else can search for the problem and find the fix. You can find all of your posts by doing a search on your user name. Tom
boring | -- 05-10-2015 @ 9:25 PM |
It is better to add your solution or more comments about a problem to your original post. That way someone else can search for the problem and find the fix. GuL
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8503 |
