EdB | -- 02-23-2010 @ 6:42 AM |
need a replacement unit for the driver's door. None of the few sources I know of have one. Would appreciate names of other possible sources. Thank you.
trjford8 | -- 02-23-2010 @ 7:51 AM |
Do you have the short roof coupe or the sedan coupe.If you have the short roof coupe the regulator from a 4 door sedan should fit. If you have the sedan coupe the regulator from a tudor sedan should fit. Did you try "Regulator Roy" who advertises in the V-8 Times?
EdB | -- 02-25-2010 @ 6:16 PM |
my friend, who needs the regulator, reports that there is an error in the ad. Does anyone else know of a possible source? It is a sedan coupe. Thanks.
Steves46 | -- 02-25-2010 @ 6:38 PM |
Ed, if I may offer a couple of suggestions. Place a want ad within the swap section of the Ford Barn website (www.fordbarn.com), periodically check E-Bay, Also you may want to check Baxters Early Ford Parts, Little Dearborn or maybe JobLots. Also, if you receive Hemmings, there is a pretty large classified section that may lead you to your find. Good luck.
mdadisman | -- 02-25-2010 @ 7:46 PM |
You might want to try the Early Ford Store. Their number is 909-305-1955. They show them in their catalog.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=846 |
