j.grif | -- 04-28-2015 @ 10:58 AM |
Is there a spacer to be used to when using chevy valves in flathead? seems a little too much spring noise. valves adjusted . Thanks
flatheadfan | -- 04-29-2015 @ 5:08 AM |
If I recall correctly you are suppose to use a 0.060" shim. Tom
j.grif | -- 04-29-2015 @ 10:08 AM |
Thanks Tom, I see that speedway has them $90 a set and would have to pull heads to insert shims. So guess will let it be.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8454 |
