pinnsky | -- 04-26-2015 @ 5:16 PM |
Is there a trick to getting the y pipe through the first cross member without having to remove the radiator?
TomO | -- 04-27-2015 @ 6:06 AM |
Yes there is a trick on some models the engine needs to be raised to give clearance. You need to supply the year of the car that you are working on for a better answer. Tom
pinnsky | -- 04-27-2015 @ 7:36 AM |
Sorry, I forgot to include the year, 1936 deluxe fordor.
trjford8 | -- 04-27-2015 @ 1:07 PM |
In the past I have jacked up the car and put jack stands under the frame near the cowl. Then I let the suspension hang and maneuvered the y pipe between the spring and the axle. You do a little twisting and turning but you can get it through.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8449 |
