snotdoc | -- 04-13-2015 @ 5:36 AM |
I am a rookie owner of a '35 coupe and need simple advice regarding the positions of the steering wheel light controls. Seems as though there are four positions available. I want to avoid leaving lights on and draining the battery!
ken ct. | -- 04-13-2015 @ 6:30 AM |
If I remember right , going counter clock wise from extreme rt hand position which would be parking lites ,next position is OFF , nxt going same way would be low beams and extreme left position would be hi-beams. Think I got it right. ken ct.
ken ct. | -- 04-13-2015 @ 6:35 AM |
Dash lites go on an off with separate switch on dashboard only go on an off only . Non-dimming operation. ken ct.
TomO | -- 04-13-2015 @ 6:48 AM |
The owners manual reprint is available from most vendors of Early Ford parts. You should also consider the excellant book on the 1935 and 1936 Ford sold by the Early Ford V-8 Club. Tom
snotdoc | -- 04-13-2015 @ 8:46 AM |
Thank you, gentlemen ! Helpful info.
ken ct. | -- 04-13-2015 @ 9:26 AM |
Probebly in the glovebox owners manual also. ken ct.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8416 |
