hardtop25 | -- 04-10-2015 @ 3:13 PM |
In torque tube... not sure of year, '37 or '40. Existing solid sleeve (not expandable one). Prevents placement of seal and new bearing w/expand sleeve. is this removable? '36 1/2 ton pickup.
TomO | -- 04-12-2015 @ 7:34 AM |
Yes the sleeve is removable. There is a procedure in the 39-48 Shop Manual reprint that shows the special tool required for this. You could probably make your own puller to remove the sleeve and seal. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=8407 |
